Re do brake lines
rasbury
Member Posts: 8,246 ✭✭✭✭✭
Started a new thread...so I two different sites for replacement lines. I looked at mine today, I'm ,20 ft to the axle from that actuator. I have 7 ft of tubing for the line to feed through and then currently, the flexible line runs along one side, tees and goes accross and each axle. The web sites show it going right down the middle which would have 17' of the tubing exposed to what ever happens on the road. Makes no sense and a lot of the tubes supplied are made to length so concerned that it will work?
Don't over think it. Press pad against piston by its ears/tabs.... While you're pressing/applying pressure, open valve. As slightly as possible.. As soon as the pressure you're creating has somewhere to go (out bleeder) it will.. Close the valve BEFORE you relieve pressure on the pad... A real quick and fluid action (no pun intended)... Your intent is to move the pad a couple mm's from the rotor. There will be no friction, now.
Once this is done and you're satisfied with the bleed, then make sure the calipers and pad spring clip is properly seated.. This will keep the pad from rattling, as well as keep the pad off the rotor during regular use...
Realize, if you've done this right you can pull one bolt/pin out of caliper and flip it down pivoting on the other, change pads, and not need to do an entire bleed again. Just use same trick as above and press enough fluid out to accommodate new pads, top off master cylinder when done, and go your merry way .
Also, make sure and use brake caliper grease on the slider pins. Make sure the rubber boots are intact and seated...
You'll be good soon!!!
Also, do these brake lines go together dry or use Teflon tape? I assume dry...
I will start putting the new lines on, pull each caliper and make sure the wheel is turning...grease the slide pins...have new bearings, rebuilt the caliper two years ago but I guess I just need to start from the basics to get it right..sigh...
use them when parked, use them at the ramp... all you have to do is drive away from them and drag them until you clear the ramp and when you get out to secure the load, pick them up and secure them to the trailer under the loop they're tied to the trailer with.
those brakes ought not lock up on a trailer disconnected. and, you really don't want them capable of locking up anyway.... what you want is the tow vehicle to rely only on it's own brakes to stop itself and about 5% of the trailered load... the trailer brakes ought to be able to stop the trailer by themselves always short of lock-up. you really don't want a locked up trailer axle in an O.S. situation. you want them stopping itself, yeah, but not locked up... just like you don't want your tow vehicle to lock up either.
