5e gas smell solved
Liberty44140
Member Posts: 4,331 ✭✭✭✭✭
first off I’m well aware that any gas smell is bad so I’ve been chasing this for a bit. When I shut down my genny I’d smell gas in the cabin. Running blower after shut down helped but that’s a band aid. I changed filters, looked over fuel lines, rebuilt carb, new choke, tried several things to stop it. Last summer I ran it and then shut it down while in the engine room to see if I could see a fuel leak or smell. Nothing found. Keep in mind that the cabin gas smell was sporadic, sometimes worse than others. This winter I read a blog on how holding down the stop button too long when shutting it down could be priming and kind of flooding it causing the smell. When I shut down historically I hold the stop button until it’s completely off. So, this year when I shut down I hold the button for just a half second at most. I just press stop quickly and that’s it. Gas smell gone! I was flooding it or something...
Interesting solution! Glad it worked.
Are you saying that your AC is running when you power down the genny? I've always ran my genny for 3-5 minutes under no load before shutting it off. This allows proper cool down.
A couple things id check. What kind of fuel pump does she have? I just had a 1 yr old kohler 30 hp on a saw mill pushing 10 plus psi on a rocker arm driven fuel pump. Should only see 5 to 6 psi. This is common on mechanical fuel pumps even on a v8.
Next is the seat on both the fuel inlet needle and the solenoid. When i rebuild them i polish the brass seating areas with a q tip and fine valve lapping compound. Its important to be sure this is thoroughly cleaned out after.
Also equally important is to check the solenoid to be sure its opening and closing fully. Honda twins will pull enough compression to run with a faulty solenoid in the off position, it's lean but runs.
https://www.pegasusautoracing.com/productdetails.asp?RecID=7550
Usually my customers using these are setting up carpet cleaning vans where a propane hot water heater is just feet from the motor.
A fuel pressure test kit is sub 40 bucks at harbor freight.
