Correct bunk positioning on a lift
davidbrooks
Member Posts: 1,344 ✭✭✭✭
I have a 342 and just got a new lift for my slip. Yeaaa. I am not convinced though that the bunks are setup correctly. If i go on the way they initially had me the rear of the bunks is at my props. That makes me nervous. If i back up a little to keep the bunks even with the transom then it is almost always leaning when i take it out.
One place i look online it says the weight of the boat should be on the keel and that the bunks are just for balancing. My keel is no where near touching. Could you all chime in and post any pictures of how you sit on the lift please?
Mine sits just as Handy stated, around the inner of that first chine. It's funny this topic has came up though, because I was told that I should maybe move it out. Most of the boats in our marina are closer to that second chine. Believe it or not, my stern I-beam looks like it has a slight bend in it. Not sure how it's possible, but has me thinking the weight should be spread out more on the beam. There are much larger boats on the same beams in my marina, so not sure.
