Loss power to engine. Also losing drive oil
caik01
Member Posts: 39 ✭
Boat it an 2002 342 with 6.2 mercs bravo3, had an issue started end of last season losing drive oil, changed the reservoir had no issue then yesterday went for a very short run and lost all oil by the time we got back to dock. Also on this short cruise we completely lost power to the port engine. I was able to jump ignition and get running again to get docked. I'm just about out of ideas to solve this problem, put in new alternators and checked volts on both motors showing 14. Any help is greatly appreciated
Loss of outdrive gear oil? You can pressure test the foot with a cheap bike tire pump.
Most common leak is fishing string around output shaft behind the inside prop.
