Engine flush or...
06Rinker27006Rinker270 Member Posts: 1,277 ✭✭✭
I damaged the water inlet on my transom for what I thought was a fresh water pickup for shore water.  Never use it as I always have my fresh water tank full.  Having a look further I see this runs into my engine.  Is this a fresh water flush for my engine? Thanks for the help!
Patrick
06 Rinker 270
Post edited by 06Rinker270 on
  • Options
    Dream_InnDream_Inn Member, Moderator Posts: 7,557 mod
    That is certainly what it looks like.  Seem like it was added on to your boat by the PO.  If you are never going to use it, you may just want to remove.  It could cause problems at some point by either letting raw water leak or allow air to enter, loosing prime.
  • Options
    Thanks John.  Well I think I should use it right?  I need to investigate now how it works.  I dont see a valve.  To be honest feel I feel a bit silly that I just found this.  The marine surveyor told me it was fresh water pick up for the fresh water system so I never thought twice.
    I am going to replace the inlet as I think it might be sucking in air.  My mechanic just put a plug on it for now since he told me the same thing, its sucking in air.
    Patrick
    06 Rinker 270
  • Options
    aero3113aero3113 Member Posts: 8,796 ✭✭✭✭✭
    There might be a check valve that will let water in when you flush the engine, could that be hanging up and sucking in air?
  • Options
    Im not sure it actually was sucking in air but the tech said it was possible.  If it was, would I be able to tell like idling rough or overheating?  Ill try and get a picture of the hose connection.
    Patrick
    06 Rinker 270
  • Options
    Looks like a check valve where it Ts in to the red hose. Read up on the flush system think motor  must be running when water is turned on?
  • Options
    Sucking in air would just cause overheating, especially when on plane.  If you can, get a good close-up picture of what is used at the "T" area.  If it is just a cheap plastic "T", you need to upgrade it if you want to use it.  It may also be a valve that isn't rated for any heat (being close to engine, you may want to watch).  I'm also surprised you didn't have any issues with winterizing, unless they used it for that purpose.  But, you still want to run pink thru the drive as well.
    Sorry if I'm on a rant, this was something I almost did on my 310 and decided the risk was not worth it.
  • Options
    Not a rant, all good to consider.  I have read all the pros and cons.  Ill get a picture of it.  Maybe Ill just replace for good measure.  The previous owner that would have installed it wouldnt cut any corners so Im sure its a proper fitting but ill double check.
    What would the issues with winterizing be?
    Patrick
    06 Rinker 270
  • Options
    Running  pressured water tought pump will fill the riser(possibly) if exhaust is not there to push it out. Start motor turn on water and flush all good.
  • Options
    .......same with your generator. If not careful you can flood it.
  • Options
    Thanks for the tips.  How long do I run it for?
    Patrick
    06 Rinker 270
  • Options
    I've seen those that actually do it, run for 5 minutes at idle.
  • Options
    Does this look like a check valve?
    Patrick
    06 Rinker 270
  • Options
    Hard to tell if it’s a check valve or a filter?? Take the top hose off, it looks like the top of it will screw off.
  • Options
    I agree with Aero, take top hose off and unscrew.  To me, it looks too small to be a filter.  Possibly check valve.
  • Options
    It does look dirty, possibly hanging up the check valve?
  • Options
    Thanks guys.  Going to have a look today and see.  Ill report back.
    Patrick
    06 Rinker 270
  • Options
    @06Rinker270 , any update on this?
