Vessel View 7 Tank Configuration Question
TonyG13
Member Posts: 1,282 ✭✭✭✭
Finally found a Vessel View manual online and have been slowly going through the process of learning all the Vessel View screens, etc., and have a question about the fuel tank configurations:
The manual states: "The % column will display the live tank volume. Selecting the refresh button will query the tank sensors and refresh the readings."
So, if I fill up the tanks and then hit the refresh button - which the sensors should then show 100% ---> Does it also reset the Gallons display (on the other VV screens) to the capacity that was programmed in (68 gallons)?
Or do I manually have to enter the gallon amount the tanks took on somewhere else in VV?
Another random factiod: there's a sensor calibration screen that lets you tweak the fuel level sender value displayed.
