Water under port side seat v 342
McGarnicleMcGarnicle Posts: 208Member ✭✭✭
Curious if anyone is seeing this, after hard rain I get water coming through the canvas were it attaches to the arch and windshield then drips down behind the seating back rest and straight into the compartment underneath the seat. We had some bad storms this week and easily vacuumed out a gallon of water if not more this morning. Because of this I really don't use it for storage but even more concerned about water seeping through the access hole to the holding and fuel tank and causing damage.
  • raybo3raybo3 Revere MAPosts: 4,235Moderator mod
    @McGarnicle If its the same problem I am having the "channel" that holds the canvas connector has to be change. I was told it was very expensive and a PITA to change. What I do is I use a roll of heat shrink tape and run it along the track and the arch. Cant really see it because its on top and problem solved.
    2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org
  • McGarnicleMcGarnicle Posts: 208Member ✭✭✭
    @raybo3 I'll have to give that a try thanks!
  • Black_DiamondBlack_Diamond Holland, MichiganPosts: 4,662Member ✭✭✭✭✭
    edited September 13
    ++ to Raybo
    Also, where the window meets the arch, the caulk is not around the arch to hull connection. The water follows the window to hull path then seeps into the arch. The water drips in from the holes/fasteners connecting the arch. I can post a pic later, but cut out the caulk at the joint and redo sealing the arch connection.
    Post edited by Black_Diamond on
    2003 342FV "Black Diamond", 350 MAG MPI, 20P 4x4 Props, PC BYC, Holland, MI
    Check the gasket on your shore power connections too.
  • davidbrooksdavidbrooks GermantownPosts: 489Member ✭✭✭
    Mine does the same during a heavy rain.  There is a simple temporary solution of just putting a small 8x10ft sheet of plastic over the seat when you put on the canvas.  This would just run the water off and onto the flooring. Another option would be to drill a small weep hole with a hose to drain it into the bilge.
