Jeff Waite 2007 320 Express Crusier
I need to replace my Aft refrigerator and it will not fit through the door.  Any ideas on how to do this?  The marina thinks the door will need to be removed but will require removing the dash to get to the all the bolts.  Have called Rinker several times but no response.  Any help is appreciated.
  • StodgeStodge ✭✭✭✭ Lake St. ClairPosts: 2,549Member ✭✭✭✭
    If you mean the fridge down below in the galley, I had to remove the door from the fridge and remove the trim around the companionway to get the new fridge down below.
  • PlanoJeffPlanoJeff Posts: 3Member
    I did that already and still off by an inch.  Thanks for reply though.
    Not sure about the 320, but my companionway is wider at the top then the bottom.  I had to stand on the steps while a friend lowered it down the wider part of the opening.  The trim around the opening on the 342 is fairly thick.  Not sure what it's like on the 320.
