NMEA 2000
jaubry
Member Posts: 125 ✭✭
I finally got the Raymarine e7 installed and the Vessel View set up the way I like. I hooked up the 2 units together using the NMEA 2000 connectors on the back of the 2 units. The issue is that I can't seem to find where in the menus of either unit To activate the the units to communicate together.
Anyone know how these 2 can start to talk to each each other?
Thanks
http://www.yachtd.com/products/engine_gateway.html
Lets start with the basics.
Did you just connect the 2 devices together via nmea2000? If so this will not work this way. Nmea2000 requires a backbone and power supply. This is very simple but we need to understand is there a backbone cable in place with a power connection. Otherwise the NMEA2000 system is not powered up.
