342 Arch Speaker Change Out
Liberty44140
Member Posts: 4,318 ✭✭✭✭✭
How hard will it be to widen the arch holes by 0.8"? Current speakers are 2006 original. They are the Clarion 1625. I found a great deal on brand new Clarion 1622's which are the replacement and ordered all 6 for the cockpit. Now looking at install it looks like they are the same size outer dimension, same screw holes, but the cutout for the new 1622 will be 0.8" wider. PIA but not a huge deal for the 4 speakers in glass but the arch speakers concern me. How difficult will it be to widen the metal arch holes? I have a dremmel, jig saw, reciprocating saw, oscillating multi-tool, etc... Thanks. Cutout comparison:
https://www.keoghsmarine.com.au/image/data/PDF/Clarion CMG Speaker Cut Out Comparison.pdf
They have trim rings without the LEDs and other options to add the depth with starboard type material. On an old boat I used a metal cutting blade on my jigsaw and added a 1x2 to the bottom plate and that allowed me better control and limited the depth of the blade so I could be precise in my cut. Worked great and could be an option for you. However, I think the little bit of material your looking to remove would be easier with the Dremel. Good luck!!
The Price is Right
MacRay Harbor, Harrison Twp., MI
That is a lot of metal to remove. More work than you might suspect.
@Stodge my factory speakers are Clarion 1625 from 2006 and the Clarion replacement after the 1625 is the 1622 that I ordered. I didnt realize until after ordering that Clarion's replacement needs a wider cutout and is slightly deeper. Apparently Kenwoods engineers are far smarter than Clarions making the replacements the same dimensions. I'll take some measurements, maybe the Kenwoods you bought would fit my holes perfectly? Do you recall the model?
I am motivated to make them work though. Clarion Marine newest 6 1/2's are over $100 a pair. These 1622's are discontinued now and are down to $65 a pair new in box. I got these on Amazon Warehouse Deals with damaged packaging but new speakers for $29 a pair delivered.
