Boat is a 2001FV340, blocks are falling apart, into pcs. Screws were stripped out causing door to slide poorly. Over time have broken up. Need new glide blocks, any ideas? thanks Sawdust
Been following this post and looking for solutions also. Have 2001 340FV and needed to replace the bottom slide that is integrated into the bottom of the attachment that the cabin door sits in. So my solution was to build it myself using 3/4” starboard, router, and router table. See attached photos. Turned out better than I anticipated and only took about 3 hours total.
wow, looks like that will do the trick! I was able to fix mine with what I had but I think part of the problem was, and I have a 270 so may be more pronounced, the curve of the hull where the track mounted- when I tightened it up it was worse- when I puts some material under the end and leveled it out, has worked well ever since. Good job though, looks great and will last I'm sure!
Great Lakes Skipper
