Engine will not start unless i wiggle the throttle handle
ddunning114
Member Posts: 2 ✭
My engine will not start unless i wiggle the throttle handle. This happened a few years ago and I don't remember what it was or how it was fixed. I want to say it was the neutral safety switch but not for sure nor do I remember where it's located to fix it. Any help would be appreciated. I have a '88 FV 250 mercruiser.
Judging by the year and model boat, I'm betting you have an alpha drive? I know on my old boat with an alpha, I had a shift cut-off switch that would momentarily cut power while shifting out of gear into neutral - yes, as mentioned, neutral safety switch. It was located on the engine at the end of the shift cables (one from shifter and one going to outdrive, connected on motor). I'm betting that needs adjustment.
ok, sorry, it's an old thread, not sure it helps icoultha.
