Stern underwater light wiring
davidbrooks
Member Posts: 1,339 ✭✭✭✭
ok so this is a little off the wall. In cleaning up the engine compartment i discovered that the center light under the swim platform had been disconnected ( wire cut). It looks like it was done on purpose by the PO. I wanted to test it before i replace it but when i stripped back the sheath i found 4 wires going to the light. All of the others have just two. This has a black, blue, yellow and brown wire. Any idea on the wiring for this? The outside is covered in caulk so i am really not quite sure of the make. The shape and size of it is similar to a TH Marine (https://www.amazon.com/Marine-Premium-LED-Underwater-Light/dp/B01JMECVLK/ref=sr_1_5?ie=UTF8&qid=1500900028&sr=8-5&keywords=th+marine+underwater+lights). I have looked around and cant find any lights that have 4 wires. Not sure if it was one of the original lights that just went bad and was left in place.
