How crucial is the drive shower on a Bravo 3 ? Mine broke off...
Lake_Bum
Member Posts: 918 ✭✭✭✭
After I had my extended swim platform installed, I saw a potential problem with clearance issues for the drive shower. Well....the inevitable happened, and it first bent it, then broke it off. I noticed it before losing it, so I still have it, just removed. My question is......for occasional use (10-12 trips a year) and rarely ever boating for more than 90 minutes continuously, is it really needed?
I don't really have any options on relocating the support brackets for the swim platform, so if I just fix the mounts for the drive shower, I think it would happen again. Thanks
Thanks for posting your recap. I also am not convinced they are required for normal boating.
What I mean is that, in general, express cruiser outdrives don't have a problem with overheating. The number of express cruisers with drive showers is probably less than 5%, but there's no epidemic of overheating. Outdrives fail mostly from corrosion or impact, not overheating.
Yes, the upper unit is out of the water when you are on plane. But the entire lower unit is submerged in moving water, and it acts as an enormous heat sink that pulls heat out of the upper unit. People see dried water scale on the upper unit, and they assume that it's overheating.
On the other hand, if you have a drive shower and don't need it, there's no real harm done (like taking unnecessary vitamins).
https://youtu.be/KXtFG5J2EaY
https://youtu.be/iPOqoLWLwPg
https://t.harborfreight.com/tubing-bender-3755.html?utm_referrer=https://www.google.com/
