The dreaded noise
terrypage
Member Posts: 165 ✭✭
Lovely day, pulled away from the berth, and suddenly a grinding noise from the outleg. Managed to limp back lifted the hatch but no indication other than it seems to be coming from the rear of the engine. Oh dear more expense (#~#<>*)
Possible causes:
1. Engine coupler - Does the grinding appear in neutral or only in gear? There would be obvious noise in the bilge towards the rear mounts.
2. Gear Set - When was the last internal drive inspection?
3. UJ Bearings would knock more than grind but could be what you're experiencing. Does it only happen when you turn? Excessive turns would likely become more noticeable.
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
