New battery
CraigybabyCraigybaby Member Posts: 1
edited November 2017 in Electrical Discussions
Hi, I just bought a 2004 Rinker Captiva 192 and need to get a replacement battery as there is only one in it. What battery should I be buying? Also the cover any idea where to buy replacement poles??
  • MarkBMarkB Member Posts: 3,962 ✭✭✭✭✭
    You sticking with one battery? Then it needs to be a crank battery. Interstate is pretty good, has a good warranty.
    As for the replacement pole, you mean the ones that sit loose and prop up the canvas at the front and back? I remember once on my previous Tahoe 19.5 I basically used a telescoping squeegee pole, the one where you set the length and twist to tighten into position.
  • rasburyrasbury Member Posts: 8,230 ✭✭✭✭✭
    I had a Tahoe 19.5 bowrider..... @markb ....great little boat, wish I would have kept it...
