Amp Question
06Rinker270
Member Posts: 1,277 ✭✭✭
Hi Everyone, happy holidays.
I am buying the speakers in the link/screen grab below and I am hoping someone can suggest a decent amp for these. I have two speakers inside and 4 on deck. No subwoofer. So does that mean 2 channel? I want to keep the current set up where the two inside can be shut off while the outside play. I know this topic has been discussed in length but a little lost on what I actually need for this set up. Santa is coming quick. I appreciate the advise.
https://www.amazon.com/dp/B01EX5M60Y/_encoding=UTF8?coliid=I3HFNBVZYMNYYP&colid=118RCSKZBGPES&psc=1
Patrick
06 Rinker 270
06 Rinker 270
Speakers inside get two and outside 4 get 2.
just get 700 watts and you will be just fine
06 Rinker 270
so 4 speakers require 4 Channels.
Yes you can run front cabin speakers from the head unit and other 4 on the amp. Your deck speakers will be pushing via rear rca output function.
works either way
Anyone have an amp they recommend? Iv seen a few on here that people have bought.
I am looking at this one:
06 Rinker 270
some cheap no brand name.
got 600 watts plus and don’t get a mono amp. Most 4 channels will have all
optiona you need. If you have to mount outside the cabin then go with marine grade amp.
so my undergirding is your current setup is 2 inside the cabin and 4 outside?
current setup runs amp or just head?
i installed my amp in a cabinet behind the headunit in the cabin
no issues
just don’t put it in a tight space next to a heat source like a window or another electrical device
@zaverin1 my current set up is 4 speakers in cockpit run off amp and 2 cabin run of head unit. Amp is inside. Its a PITA to get to so I will be repositioning.
The amp I post is 600 watts 4 channel JBL marine amp. I think I will be good?
06 Rinker 270
Plug n play since it’s all the same besides brands.
put it somewhere where amp will have air flow
i am just saying you don’t need to put it in the wide open lol
https://www.crutchfield.com/p_206KXMA404/Kicker-44KXMA400-4.html?tp=61752&awkw=344748252447&awat=pla&awnw=g&awcr=186330246636&awdv=t&awug=9026823
unless mounted to the dash lmao
thats if all your speakers are driven by the headunit.
this means amp via rca and front via speaker wire.
you probably have a 5 channel or 2 separate amps one for speakers and one for sub stodge.
What Alpine amp do you have?
06 Rinker 270
where are most car amps mounted? Oh the trunk
Does it matter if I have a clarion stereo(which I do)? Meaning will this hook up easier, plug and play, than the JBL I posted?
06 Rinker 270
06 Rinker 270
You might have to extended the wires but it’s simple
you can drill
lets say thru a devider and move it over
