How do you know type of trailer?
New to group! New to owning! Awesome and so much to learn. Have a 2005 250fv and need a trailer. How do you which type or lind to buy?
  • Options
    Cableguy GregCableguy Greg Member Posts: 5,012 ✭✭✭✭✭
    edited December 2017
    I will echo what Al states about a Trailmaster trailer. They custom build them for the boats and have all of the specs for Rinkers. When I bought my current 280EC, I purchased a generic Venture trailer for the boat. I never liked how the boat sat on that trailer. I had a Trailmaster under my 232cc, so I had experience with them. After two years of struggling with the Venture, I sold it and bought a custom built Trailmaster for my 280. The boat goes on and off like a dream. There are a few dealers in the Buffalo area.
    http://www.trailmastertrailers.com/
    No matter what trailer you get, spend the extra few dollars and upgrade to the LED lights. They are worth every penny spent!
  • Options
    davidbrooksdavidbrooks Member Posts: 1,344 ✭✭✭✭
    My last boat was purchased with a new loadrite trailer spec'd for the weight and size +an extra 15% lbs.  Everyone is giving you good advice but i would also add that it is important to have it properly setup for your boat at the boat yard.  This is done by loawering the boat on trailer with a crane and adjusting the bunks and stops to make sure it is sitting with the right amount of weight on the tongue.  Critical for safe towing.
  • Options
    MsquaredMsquared Member Posts: 30 ✭✭
    Great advice! Thank you
  • Options
    jhofmannjhofmann Member Posts: 430 ✭✭✭
    Check your towing laws, Some states only require brakes on one set of axles, others like Connecticut reqiuire branks on all axles. You will most likley have a tandam ( 2 ) axle trailer like I have for my 2000 FV 242. If you go heavier planning for the next bigger boat, you may have a tri-avle ( 3 ) trailer as seen for some of the FV 270s. I went with a 10,000 lb dual axle trailer which is overkill for my 242, but will handle what I hope is my next boat, a 270.
  • Options
    Forum friends just keep getting better. Thanks for the advice!
  • Options
    GMSLITHOGMSLITHO Member Posts: 1,559 ✭✭✭✭
    Hi bought a 270 last year,and needed a trailer  I bought this from trailers direct in south Jersey it was around 4,000 ,he delivered the trailer to long island where I bought the boat had the marina load it on the trailer and then he delivered the trailer with the boat on it to my house in New York state for a additional 600 ,the boat is 7500 lbs and the trailer is rated for 10,500 towes great ,never had a bunk trailer before only roller trailers but its easy to load and tow
  • Options
    Thanks. Ill look
  • Options
    rasburyrasbury Member Posts: 8,239 ✭✭✭✭✭
    That looks like my trailer for my 270...brakes all four wheels...i do have surge brakes.
  • Options
    Just ran across this and thought it was interesting.  They always say you need the right weight distribution on the tongue but i never completely understood why...especially when i was struggling with all that weight.  I wont complain again.
    Watch this. https://www.youtube.com/watch?v=SbdF5AZmINc
  • Options
    aero3113aero3113 Member Posts: 8,810 ✭✭✭✭✭
    Great demonstration
  • Options
    Sure clears that up
