Davits on the new 370
Stodge
Member Posts: 2,738 ✭✭✭✭
We went to the Detroit Boat Show this weekend. Got to meet Kim Slocum and told him about taking our 342 around Huron last season.
I climbed on the 370 and it seemed a little more cramped than our 342. Really nice below and still has a separate shower. but when I went to get off the boat I noticed the placement of the dinghy davit cut-outs. The are off center pushed over to the starboard side. Given the curve of the platform I was trying to figure out how in the heck that would work. Nobody at the show seemed to have a good answer though.
Re Davits: I have seen many 360s with a dinghy. Unless Rinker has moved the locations on the 370 there should be no problem. If Rinker has moved them they should work. Kim cruises on a 370 all the time. Did you ask him?
I guess I was expecting it to be "much" bigger. Course the LOA is only 10 inches more.
The davits were well to the starboard of center with one almost all the way on the starbaord edge and the other to the right of center. I asked Kim about it and he said it was because of the ladder placement.
Well, I think this so called 'myth' is mainly because the newer boats are rebranded with the LOA as part of it's length, compared to the older boats that didn't. It's not just a Rinker thing, they've all done it.
I've seen the 360/370 literally rafted to a 342 probably 8-10 times over the last couple years. Heck, there are several of each on my dock. There is a difference in the areas MT has mentioned, but it really depends on how much of that matters to someone. For instance, you can still fit two people on the v-berth bed on both, not any more than that (yes you can walk around on the 360/370, but that is just walking space). Couch or wrap around seating, that is really a preference and both take up about the same amount of space (I've measured and see it between the 390 and 400s, both literally take the same space). Helm area is larger, but not the 3 feet larger between the boats.
Davits, I'd be curious if they changed. @LaRea has a 370, maybe he can chime in about the davits.
That's just because as the boats get wider, they have more room to move them to the side. I have mine on the davits and they boat doesn't stick out the side.
