Broke only key to cabin
rb11633
Member Posts: 15 ✭
well, actually my wife broke it-- normal Ace hardware can't replicate- 2014 360EC-- locksmith? Would Rinker customer service help? Thanks
Best Answers
Optionsreneechris14 Member Posts: 3,134 ✭✭✭✭✭Is the door open? If it is you take out the latch and there's a number on the mechanism. Forget site but other guys will chime in and give a link. You don't have to blame it on wife.lol2005 Rinker FV342 Pawcatuck river,Ct
Optionsreneechris14 Member Posts: 3,134 ✭✭✭✭✭Don't break the door it cost more then a small child.2005 Rinker FV342 Pawcatuck river,Ct
Optionsaero3113 Member Posts: 8,796 ✭✭✭✭✭I went to a local locksmith, they were able to use a motorcycle key to replicate it.2008 330EC
Optionsaero3113 Member Posts: 8,796 ✭✭✭✭✭But like @reneechris14 said there should be a code on your latch.2008 330EC
OptionsCableguy Greg Member Posts: 5,011 ✭✭✭✭✭The key number is located on the inside handle. It is stamped in the black part of the latch. You might have to move the black webbed handle to find it. If the key is the original key and you have the number, you can order a new one here... http://mobellakeys.com/ I have ordered keys from them and they get here fairly fast.
It is a 3 digit number, usually 8xx or 9xx.
Usually you can carefully dig out the old broken key part with a pick or small jeweler screwdriver. If you can't get the key out, you might have to call a locksmith to get it out.
Go Steelers!!! -
Optionsdavidbrooks Member Posts: 1,344 ✭✭✭✭They are mobella keys. http://mobellakeys.com/ if you have your key you should be able to get a number off of it and order a replacement. I did this so i could have spares.It's 5 O'Clock Somewhere!
^^^^ THIS!
