@memorymaker are you just looking to replace a defective switch or are you trying to add the dual voltage feature to the fridge? If the latter, you first have to confirm that your compressor cans do both. When I checked mine I found it was 12 volt only.
As I recall, the fridge on mine only works on 12v and you have a power inverter to convert 110 to 12? Any way, just search eBay with your model number so that all available stuff comes up....
check to make sure you have 110 to the converter on mine it was wired from the stove so the switch for the stove had to be turned on at the breaker panel
Yes I do when fridge 110v switch is on. If I turn off house battery, fridge shuts off.
