Bad news from mechanic
nyactress123
Member Posts: 6 ✭
I am hoping to get some advise on this. We had our boat overheat due to a broken serpentine belt. We have a Volvo 5.0L OSI - EF. We replaced the belt ourselves. The engine wouldn't start. Had a mechanic look at is and found that our spark plugs were sightly rusted and a small amount of water was in the cylinders.
We checked the compression ourselves and found two cylinders low (2 @ 90 vs 150+ for the others) Added Marvel mystery oil, went back the next day cranked the engine to blow out the oil. Got a spritz of liquid (most likely oil) when we did this. We had the mechanic go back and check the compression again a week later. They also found low compression on two cylinders, but was told it could be within tolerance. They thought the water could have been introduced through the exhaust originally. But before they began work, they did a video inspection and came back and said two of the cylinders had a very bad rust condition. They felt that even if the work was done on the exhaust that they can't guarantee that the boat would be ok and recommended to replace the block or engine.
Any advice would be appreciated.
Andy
There was no "pitting" of the metal and the smooth surface was restored. It was an old, somewhat classic car and I was just thrilled to get it running, I wasn't looking for a reliable daily driver, and a boat needs to be reliable. I'm not a pro mechanic by any means, but I would venture to say the seal of the piston rings requires very smooth bores and any pitting of the bore would reduce compression or worse. I think an engine shop could rebore the cylinders to fix that. I've heard the 5.0L GM block is really not ideal for cylinder capacity increases, which isn't the case with the 5.7L. I'm sure others on here with more experience could chime in with their opinions.
Andy
Poor compression , within reason , in two cylinders will not prevent that engine from starting and running.
