Sheila
cory143
Member Posts: 20 ✭
Ok I bought a 2002 rinker 310 with twin 350 mag. On our 3 outing cruising about 1/2 to 3/4 throttle the boat fell off plane. I realized one engine was not running. My first attempt to restart it did nothing. The second time the engine fired up but was running rough and backfired a couple times then died. I tried again to start the engine this time it turned over a few cranks then hydrolocked. I pulled the plugs and drained water out of 2 cylinders. I replaced all the plugs and riser gaskets ( mechanic said they had failed and let water in the engine ) after all this I tried to start the engine again and nothing, tried a little starter fluid and it started backfiring again. This is when I learned if it backfires it’s able to suck water through the exhaust and into the engine. Everything is telling me my problem is electrical. After trying a few things and swapping coils still nothing. Had a mechanic go through it changing about everything from one engine to another still nothing. His diagnostic machine would not accept my 2002 system so hear I am looking for any help I can get.
Thank you in advance
Started as an intermittent cut out and backfire and got progressively worse to the point of a no start. Did all the fuel and spark related things with no improvement. Turned out to be an orange wire that runs from the positive stud on the starter to the coil to provide full 12 volt to coil when engine under load. It had loosened off and the coil was cutting in and out.
Fixed the connection and runs perfect since.
