getting the transom asy back together
rasbury
Member Posts: 8,238 ✭✭✭✭✭
So, I posted on my thread to lee things together- either everyone is on their boats (hope so!) or its not showing properly.
It as most seems someone had this apart as the thrust washer in between the gimbal ring and housing I swear was not there when I took it apart. Anyway, the water tube looks like it should kind of press in by the ring the bellows goes on- housing is also indented. When I put the bellows on it seem to interfere so I pulled it all apart and will have to clean and re install. So does that hose push down in there after the bellows is installed or just hang there Willy nilly?
The holes I drilled in the transom I need to fill with something an I want to put some sealant on the seal for the gimbal housing. I'm hearing that 3m 4000 or what ever will be a permanent bond that will pull gel coat apart- not sure I want to seal it that well...thoughts?
take it to a shop
So, filled the back up with some water to test. Keep in mind no motor. So, my transom did not seem to be leaking any more which was good news. My thru hull for my raw water pump was leaking pretty good. Also, there does seem to be a little water dripping through around the trim manifold somewhere. So, will tackle the thru hull first, leave everything else alone and deal with it one by one. Looks like I had multiple leaks to deal with. And NO, I'm not taking it to a shop.
sales is sales.
do you think maintenance on boats is cheap at marina lol
anyway I wish you all the luck and hopefully you can get her done.
time is precious and spending few thousand on the repair bill would of put you back in the in water a lot quicker.
