Rinker 242 Fiesta Vee Not Planing
Coolweld
Member Posts: 14 ✭
I need advice, I have purchased a 2000 242 fiesta Vee with the 5.0 L Mercruiser and Alpha Drive. My wife and I have done extensive work to the boat and motor to make it seaworthy. We decided to take it out for our first trip last evening the engine idled ok, however when I throttled up the RPM's stayed at 2600-2700. It should be able to easily go to 4400 RPM. Could it be a Prop issue? timing issue?
Its been a project boat for the last three weeks, any advice would be very welcome.
So far no luck with going over 2600 rpm , going to change spark plugs and probably rotator and distributor cap today...if that fails we’re Going to have to hire the marina guy soon. At $130 per hour that’s gonna Hit hard.
on WOT it’s rpm was 4100 speed was 32 mph. My tachometer is sticking so I am unsure of the exact reading. The only way to be sure would be a tach on the motor while running.
It ran smooth for two hours. There was nothing in the new filter. I suspect the motor had just sat too long(4 years). The prop is awesome 15-1/4” with a 15 pitch, it’s the Mercury Black Max. Our old prop was so chewed up it had to go.
I am thinking of doing a timing check just to be 100% sure the boat is running optimally. If anyone has a link I’d be willing to learn.
Thanks again.
