Leak in Water Pump?
Willhound
Member Posts: 4,185 ✭✭✭✭✭
I've noticed a bit more water than usual in my bilge lately, and coming off plane after a run of about 40 minutes yesterday my bilge pump kicked on, which isn't unusual, but it ran all the way back to my slip and was still letting out a steady stream when I stepped off to tie up. So I estimate at least a good couple of gallons of water in there.
I shut the engine down and opened the hatch. Couldn't see any leaks in the hull our around the transom assembly. Fired the engine back up and it did look like water was dripping from around the front lower part of the block but not a great volume, still more than perhaps should be though.
I did have the water pump pulled and re-built last year. Engine was running fine, no water in the oil.
So I'm thinking maybe a loose bolt or two on the pump housing, or a loose hose?
Is there anything else down under there I should be checking?
Will be back on the boat on Tuesday and will also bring my snake camera so I can safely peak under there with the engine running.
I guess my initial question should have been more clear, that is, besides the water pump/pump housing, and/or the hoses connected to it, is there anything else in that area that I need to check for leaks?
I think I was getting confused. I had the raw (sea) water pump rebuilt last year. This leak appears to be from the standard GM water circulating pump up on the top front of the block. I'll be going for another look myself tomorrow since he can't get there until Wednesday but I've asked him to go ahead and order the pump on spec. From what I can see it's the original pump from 2000 and about 400 hours running time and for the $100 it's worth I want to have it on hand and will likely change it regardless. Something I could easily do myself, but I work all the rest of the week and have a 3 day trip planned for the weekend so I'm just going to have him do it. He hasn't seen the boat since spring anyway so it's a good chance to have him take a look around the engine compartment. I trust this guy completely. If he says it needs work, it does. Quite often he'll give me a heads up for future consideration. And a few times he's let me know that work I thought needed doing didn't need doing at all even though he could have made a buck out of it.
He get's a Cuban cigar and a bottle of port from me from time to time...
