trim hose routing
rasbury
Member Posts: 8,238 ✭✭✭✭✭
This is driving me nuts.....the trim pump lines that go from the pump to the manifold....bravo III.....there is a gray and a black one. The gray one has a longer bend to it at the fitting at the manifold so it can go over the black hose- so it should be the black goes to the inner hole in the manifold and the gray goes over top of that one to the outer hole in the manifold- diagram attached from mercruiser says the gray one is the number 3 going to the first hole in the manifold....what am I seeing wrong? I could not get it assembled that way...the number 3 hose is the gray hose....
