Mercury Vessel View 702
dgelles
Member Posts: 4 ✭
2011 Rinker 310 with Vessell View installed. The previous owner had this installed last year and when I purchased the boat and the RPM settings showed different values as it is supposed too. For some reason I lost the settings and then did a complete system startup and now it doesn’t read independent RPM values. Anyone else have a similar problem or know how to correct.
Thanks
David
Thanks
David
Best Answers
OptionsDream_Inn Member, Moderator Posts: 7,558 modWelcome to the forum. Sounds like you need to go in under the settings and configure to two engines.
OptionsStodge Member Posts: 2,738 ✭✭✭✭Assuming you have 2 engines and by independent you mean port versus starboard, it could be that the identity of your port engine was set back to starboard.
The way it was explained to me when I added vessel view to my boat was that all Mercruiser engines were created with an engine identity of starboard in their ECM, much like how they all have power steering pumps even though only 1 is used.
A friend of mine has the Rinda set up and was kind enough to reset the identity of my port engine to "port" so that my vessel view would not be confused. Could be the same thing.2002 FV 342 on Lake St. Clair - Past Commodore SHC - Vessel Examiner USCGAUX
