3-mile LED anchor light
LaRea
Member Posts: 7,503 ✭✭✭✭✭
Is there a 3-mile LED anchor light that costs under $200?
For safety, I want a light that's super-bright, and doesn't fade when the battery gets a bit low. But the cheapest I've found is this one for $230:
https://www.westmarine.com/buy/signal-mate--pedestal-mount-led-all-round-anchor-navigation-light--13836200?recordNum=50
There are plenty of 2-mile LEDs that cost less, but the 3-mile lights seem to start at $230 and go up from there.
This is the exact one I purchased: https://www.backtoboating.com/products/led-anchor-masthead-navigation-light?variant=13826763143
I needed the longer pole and needed it to fold down to fit under a bridge I routinely go under. I will say, it is extremely bright. When rafted up, those tied on my sides say it lights up the inside of their cockpits too much. We turn it off to look at the stars.
In daylight, my nav lights can't be seen at all, so I have to belly-crawl up on the bow to see if they're working. I checked them last weekend, and as usual, one was burned out. I decided I was tired of never knowing when my nav lights would crap out, so I bought these LED lights from West Marine, on sale for $40:
https://www.westmarine.com/buy/west-marine--deck-mount-led-navigation-lights--15761588
I just hooked them up to a power supply at my desk ... Sweet Fancy Moses, they are bright.
[edit, there's no indicator light. It's a screw hole to secure the metal housing.]
I'll try to get 'em all hooked up this weekend.
They are MUCH brighter. Here's a shot of the two green lights shining on the wall in the forward cabin, with the door closed.
[edit: There's a screw that secures the metal housing to the plastic fixture.]
Note, the lights do not include fasteners. You will need four 1-1/4" screws and two 1-5/8" screws. (My old lights were installed with 1" screws.)
I don't really care about power consumption when I'm running, but for what it's worth: the old incandescent lights used 0.75 amps each, and the LEDs use 0.07 amps.
06 Rinker 270
Now, if I was tied up to a boat with people hanging out on the flybridge, different story. It would be at eye level for them, and probably would be annoying. But in that case, we could use their anchor light and turn mine off.
06 Rinker 270
