Coffee Maker Plug on 342
The coffee maker doesn't work on my 342 and I suspect it came unplugged from the side of fuse panel.  I've read the posts about removing the microwave to gain access and it is something I'd rather not do if I don't have to.  Is there a way to look and see if it is actually unplugged before I disassemble half of my galley?
    When I removed my coffee maker it was a 1 way trip.  The connection was not a "plug" but direct wired instead.  Could be that Mr. Coffee has kicked the bucket.
    The removal process I used was to remove the screws under the coffee maker, then use a hot knife to cut the plastic brackets on the top of the coffee maker to allow it to come out.  I guess I could have put it back in just using the bottom screws.  But my intention was to use the space for storage.  I have yet to make a proper insert for the space.  I put large cups in it.  But some day I'll get it more finished.
  • IanIan Member Posts: 2,774 ✭✭✭✭
    I think on my 310 by pulling the switch panel I can get to the back of the coffee maker. And it’s plugged in. Not sure about the 342 though.
  • raybo3raybo3 Administrator Posts: 5,455 admin
    My 342 is a "plug in"
    It's magical feet to the micro out with put dismantling the galley I speak from experience. You can buy a $20 borascope there's a gap over the top off cabinet. The electrical panel comes out pretty easy that's where it plugs in. My micro was broke so it was coming out. There's 4 screws that go up threw the bottom to hlod a piece of plywood the micro is screwed to. Then up push the micro back about an inch to unscrew the black starboard piece and the micro with come out gingerly.
