Bravo 3 Stern drive leak at the hose from the gear lube reservoir.
Bayrunner
Member Posts: 177 ✭✭✭
I need to change out the hose coming from the gear lube reservoir. I can see the leak and wonder if there is enough room to change the hose out of the transom wall to the stern drive or let the marina owner repair.
Best Answers
Optionsreneechris14 Member Posts: 3,134 ✭✭✭✭✭Are you sure its the hose or the plastic piece that goes though the transom.sometimes the hose pulls up on the 90° part of the plastic piece. When the drive is all the way up. Part is 10 bucks put a pisser to change.2005 Rinker FV342 Pawcatuck river,Ct
Optionsreneechris14 Member Posts: 3,134 ✭✭✭✭✭Ok good. Make sure the right lenth hose is used to replace. Be very careful of the plastic barb fotting.2005 Rinker FV342 Pawcatuck river,Ct
