Port motor cursed
Well it seems that way.  Last week the shifter cable for the port outdrive failed leaving the drive in forward.  Over the weekend the starter switch failed.  It spins, no spring, no stop.  Now when I go to start port I get a soft click the first 5 or 6 times I turn the key, then it will catch.  Most likely the slave solenoid.  I think port is jealous of the new starboard motor.
Shifter and starter switch have been repaired.  Slave solenoid is on order.
