97 Rinker 240 Fiesta Vee questions
Stever00
Member Posts: 145 ✭
Anyone here bring me up to date on the ins ands outs of this boat? I have parts of the full enclosure. I know some ot is missing but not sure. How do you drain fresh water tank in winter? Boat was dry docked at marina. Trailer bunks not set up right, needs waste tank pumped out but got to get trailer fixed before i can put it in water to go to marina. Can this be done at home? Has Surge O Matic # 6 trailer brakes. How do you keep it from putting on brakes when backing. It does not have the electric switch or manual one. Can it be locked with c clamp when backing? If any one has trailer for boat like this I would like to see how bunks are placed on the hull. Its a 25 foot EZ loader trailer from about 1999.
My brakes are set up similar to a titan 10 or 20 model, google pics for illustrations.
I recommend any trailer boater buy a macerator pump and line to pump your holding tank into your septic or sewer system at home. Look up diy macerator tank pump. The best thing about trailer boats is no need for marina or marina fees.
My 235 doesn't have a fresh water tank drain. My hot water tank does I will turn on all the faucets and then turn on the galley pump at the end of the season. Once empty put 2 to 3 gallon of rv antifreeze in the system and run it through. Once again turn on the pump and run hot then cold water on each faucet until antifreeze comes out. Then you're done. Have a beer to celebrate.
I cant help you with bunks as i have a roller trailer. Id rather have bunks. I want the lower center of gravity.
I dont like alcohol stoves, sure it doesn't put out the co2 like propane but lp isnt a spill/burn hazard. I only boat in the summer so if i do need to cook on a stove top(do all the time on the sailboat, have not on the rinker) all the hatches and doors are open. I run a generac quiet genset on my swim platfrom to run the ac at night so for me a co2 and fire alarm are mandatory inside the cabin. The alcohol vs lp debate is as bad as politics or religion.
If i keep my rinker and not upgrade this winter i will have an lp grill mount made for the swim platfrom or transom.
In order for me to start boating year round ill need to either invest in waders or find a driver to either run the excursion or drive the boat. Doing it solo i have to get at least thigh deep in the water. I guess i could get waders!
The holding tank was again a part of the toilet but instead of pulling toilet to empty you had a tube running up to a pump out fitting. It emptied just like a holding tank
I don't use a marina and all season long i never even passed a marine. Where i launch has an rv dump spot where I can use toilets, trash dumpsters and gated entry for safe weekend parking. I stop before heading home, toss my trash and clean the toilet so its fresh for the next trip
Maybe post a pic of your toilet? Id post one of my old pump toilet but after realizing it wouldn't dump easily, it took nearly an hour to clean, i tossed it in one of the dumpsters at the park. I then installed ordered a new one from Amazon and had it before my next outting.
