Headliner falling down
jreau
Member Posts: 16 ✭✭
I have a 1994 Fiesta Vee 265 and my headliner is falling down. Any ideas on what to do? Is it expensive to replace? Could it be removed and paint what's under it? Any ideas would be appreciated
If only on some spots you can make a very small puncture to introduce some 3M with a small tube that goes on to the nozzle of the spray can and let it tack well before pressing together and try to use a even pressure (not to much )with a small batten or any flat surface that will conform to the contour of the roof
Second if it is a large surface peel the headliner back and used the method below
Most of the time the headliner has a foam backup so uneven surface of the fiberglass does not show and then when it comes unglue some of the foam will be stuck on the material and some on the fiberglass .When you apply any type of glue in this case 3M and coat both surface and let tack good before putting both surface together when you press the surface back in place any uneven pressure will compress the foam and will create a uneven surface. The best way is when you are ready to press the surface together use a kind a flexible batten as long as possible to conform to the shape of the roof and do not put to much pressure on the head liner and move along slowly. Start at the widest part and have a buddy hold the material in front of you.
If you need more info let me know
X
Home port: Hammond Ind.
