AC still getting HPF
06Rinker270
Member Posts: 1,277 ✭✭✭
Hey guys, still no AC and getting HPF error. I have primed, checked seacock, played with programs. Maybe it's the pump? Getting too hot for this to be a little problem anymore. Thank you everyone.
Patrick
Patrick
Patrick
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
Please tell me if this is what's happening:
1.You turn on the AC and the fan comes on then the compressor engages. The unit runs for a bit then the code comes up. This is definitely a water flow problem.
2. You turn on the AC unit and nothing happens at all (Maybe a click) then the error code. This would be a much more complex problem that may need a service call because there is a miriad of things that could be wrong.
Please keep in mind that the unit will over heat very quickly with no water flow and the more times you try to start it it gets even hotter.
Yes running the water through the intake will alleviate air locks but I am confused as to how you saw it coming from the intake as it's a seacock on the hull of the boat near the keel.
06 Rinker 270
John...good to know about the seacock. Getting adjusted to this lift is interesting.
06 Rinker 270
06 Rinker 270
06 Rinker 270
06 Rinker 270
So, long story short, with the age of your boat, I'm betting it may be your seawater pump, not the impeller.
06 Rinker 270
By the way, yes sometimes the sea water system needs to be received of air, due to air locks. That happened to me 2 weeks ago. Installed a new impeller and started the engine while in the water on a ramp. Very little water pressure, so we bled air via a plug at top of engine and bingo water pressure came up.
Mark nailed it. Frothed oil is a very bad thing... Air bubbles don't lubricate. They don't cool, either.
I'd rather be a quart short than a quart high. Any day of the week. For this reason, I'll fish the drain out of the bilgebefore I try to suck oil out. I've no trust in that method.
Is getting to a temp of 175 normal for idle?
@Dream_Inn did you add Vesselview? I don't have a visible water pressure gauge.
06 Rinker 270
VesselView, yes I added it in myself when I first bought this boat. It will display about anything you'd ever desire from your engines. Gives you in plain English what an alarm is if one goes off. Well worth the money (I found mine on Ebay and the whole thing only cost me a few hundred).
I am going to do some research on VesselView. I really like how it diagnoses the alarms rather than just beeps. Appreciate all the help.
06 Rinker 270
ill be starting her up Saturday and see how quick the temp gets this time...stay tuned
06 Rinker 270
