Dock/city water regulator
IanIan Member Posts: 2,798 ✭✭✭✭
On my 03 FV 310 I have not had much luck with the Jabsco 44410 series of inlet/regulator as the fitting seems to pop out easily as its just pressed in. I have seen there is a Shurflo unit but its rated to regulate to 65psi and the Jabsco is 35psi and its original equipment. My question is would I expect issues with the water systems on the boat running at a higher pressure (nearly double) or is the 35psi just because that is what the regulator does but the systems can take it?
  • Options
    explore7425explore7425 Member Posts: 150 ✭✭✭
    65 is pretty high. I bet the dock pressure is not nearly that high.
    Bella Sabrina II  370EC
  • Options
    rinker312rinker312 Member Posts: 255 ✭✭
    I took the guts out of my regulator a few weeks ago and we have pretty good pressure at the marina and so far no problems
  • Options
    JC290JC290 Member Posts: 706 ✭✭✭
    Doubt you would ever see 65psi that is a lot of pressure. Never looked at these but I would wonder if you couldn't find an adjustable one?
  • Options
    Not sure what the town supply is. But is allowing up to 65psi instead of 35psi going to be an issue for the boar water system - piping, joints, faucets etc
  • Options
    connections would be my first concern. is there a rating on your water lines for max PSI
  • Options
    Not that I can see. Only indication is the fresh water pump rating of 35psi.
  • Options
    so i talked to every one i could and looked for more information on this, the best i could find was do not exceed 50psi. The lines they say will hold more, but no one has tried that i talked too. some camping people are running 60-65 psi, but i haven't found a boater as of yet running that pressure. In our area city water pressure is 60 PSI at the street. They do have inline regualtors that are adjustable. Best I have good luck
  • Options
    MarkBMarkB Member Posts: 3,967 ✭✭✭✭✭
    Can you fit a regulator on the city hose connection point?
  • Options
    They make those regulators for RVs but the connection has a built in regulator. Mine is made by Jabsco.
  • Options
    As per my original post so is mine. But have found the quality somewhat to be desired with the second coming apart at the hose connection.
  • Options
    Thanks. To be safe I've ordered another Jabsco 35psi and see how that goes
  • Options
    bella-vitabella-vita Member Posts: 411 ✭✭✭
    I have the same problem mine it is leaking at regulator also( read a lot of bad reviews about the jabsco ) so I ordered a
    new Shure flow but it says it's rated for 50 psi I was gonna try it out but I would have to cut hole bigger an don't want to do that also was concerned about the 50 psi I'm just gonna order another jabsco
    2002 Rinker FV 342
  • Options
    Yeah, I checked with Rinker an they didn't recommend to go over what was fitted. Mine popped again the other day and with  new one on order I decided to put some superglue around the brass spline and tapped it home. Seems to be good for now, as a precaution I disconnected when I left today. I am thinking I will look for something more flexible to connect at the fitting, perhaps to absorb the wake shocks that may be a factor.
