You're in Chicago? Try channel 27. That's the Seatow automatic radio check. Also, make sure your radio is set to high power. (By the way, your radio is a VHF, not CB ... they use different frequencies.)
Just don't ask for a radio check on 16. The coasties here get grumpy at folks who do that. Over here channel 69 is the popular one for recreational boaters.
To change power level, press and hold "ENT" for two seconds. That toggles between 1 Watt and 25 Watts.
Switch to Ch 27 and do a normal radio check request. It will play back a recording so you can hear how your radio sounds. The transmitter is just south of downtown Chicago.
Seatow uses ch 24,26,27,& 28 depending on your area. You can look it up on their website to see which is the best to use.
It works really well, I just replaced the antenna on my fishing boat and checked the connection with a radio check with seatow. With the upgraded antenna I was impressed how far I was getting a good connection.
It depends how busy channel 16 is in your area. In Chicago, I'll bet 16 stays pretty busy, so it's important to reduce unnecessary traffic. On the Potomac River, there's not much radio traffic, and I've never heard any complaints about using 16 for radio checks.
In Canada, north shore of Lake Ontario, it is routine to hail coastguard on 16, and they will advise what station to move to. I always hail and request (in one breath) a radio check on 16, so they can ascertain the reason for my call and switch me off. They are always friendly, never had a problem with them on 16.
Not hearing anything at all? OK, possible problems are the speaker, the mic and the antenna.
Tune to ch 68. With the volume at a mid level, turn the squelch all the way down (counter-clockwise). Do you hear static? If yes, then you know the speaker is working.
While you're hearing the static, press the transmit button on the mic. Does the static stop while you are pressing the button? If yes, then the mic probably works, and it's probably an antenna issue.
Trace the antenna cable from the back of the radio all the way to the antenna. Are there any cuts or other damage? When you installed the fitting on the cable, did you have any problems with it? Did you follow the instructions exactly and make sure the braided shield has a good electrical connection to the fitting?
I've had a uniden marine radio for years and they have good customer support when I've called about other problems I suggest you try the customer support line:
Our Uniden representatives will be happy to help you with any matters regarding the operation of a Uniden product, available accessories, or any other related matters. For Product Support on: Scanners, Marine Radios, & CB Radios 1-800-620-7531 Mon-Fri 8:00A.M. to 5:00P.M. C.S.T
For Product Support on the following models: UN111, UN114, UN119, UN302, UN308 UN311, UN352, UN354, UN355, UN702, UN704, UN717, UN718, UN719, UN720, UN721, UN747, UN748, UN749, & UN904 Please contact ESI Technical Support at 212-883-8838 Or By email at techsupport@esicellular.com
Doing a radio check on channel 27 and not hearing a playback recording. LaRea said:
Doing a radio check on channel 27 and not hearing a playback recording. Something not right. I do hear static when i turn the squelch counterclockwise.
OK, so we know the speaker works. The Coast Guard's signal strong enough to be heard by any radio anywhere in your area, so you're not receiving at all. Gotta be an antenna problem.
Was this a brand new installation, or did you use a pre-existing antenna? Where is the antenna mounted? Have you traced the entire length of the cable to make sure it isn't cut, damaged or spliced?
Ok so, had the radio on and i heard some local chatter on channel 16. Did a radio check and promptly received a response. So, my install turned out to be ok.
06 Rinker 270
06 Rinker 270
Or
good luck with it
Art
