Engine won't start
JohnP
Member Posts: 11 ✭
I have a Rinker 270 2002 with a 350 mercruiser engine, the boat has been fully serviced during the course of the winter and have checked the engine and it won't start, I called in the agents and they could not find a fault, however they indicated the crank shaft sensor was not giving the correct reading and they replaced it.(The day they fitted the crank shart sensor for some reason the boat started but we went ahead with the replacement) The boat worked for about 3 weeks and again won't start
Top of your engine, right behind the throttle body is a red button/circuit breaker. Reset it by pressing it down.
John, does your starter turn, or is everything dead?
Check the ignition cap and rotor. The rotor will burn through and will go to ground on humid days. I chased the same thing for weeks
