Full front deck replacement -
greg
Member Posts: 3
Hi Folks,
Wondering if anyone else has suffered this problem? As a result of water migration through the front windshield mounting track screws (through gel coat and into balsa core - no backing material runs under the gel coat for screws to secure into). Water has saturated/rotted the entire front deck balsa core and it had to be replaced (about $10,000 repair). Moisture evident from the anchor locker to top of dash, mainly to port half of deck. Moisture meter readings in high 30's. Lots of photo's and video if needed. Thanks for any info. you have.
Greg
Greg
