Docking tips
craigswardmtb
Member Posts: 1,015 ✭✭✭
This is my first twin screw and I had a couple questions. What is your guys method for keeping the boat pinned to the dock when the tide and wind is not in your favor? When pulling into a fuel dock what angle are you approaching at and what is your method for swinging the stern against the dock on the quick? I am typically leaving the drives straight and using the controls as if i were operating a tank but it doesn't usually work well for the above scenarios. This is all so different than my single screw 270. Although getting into slips is a lot easier with the twin. I have some lessons in June but always appreciate your guys intel.
On your first question, this is a book length subject because there are so many situations. How about posing one of them and someone, maybe me will try to give some suggestions.
On your second question I find that approaching the dock at roughly a 30 degree angle is about optimum. If you do most of your power input (going forward) with the outside engine and point the bow where you want it with the wheel, you will get the result you want. If you need to slow down the forward motion, do it with the inside engine and turn the wheel all the way toward the dock.
Using the engines in this manner, you will be vectored slightly sideways toward the dock because the engines are not on the centerline of the boat.
To get the stern in, give both engines a short burst of reverse with the wheel turned toward the dock. This will pull that end of the boat right in without moving the bow much.
I am sure there will be lots of posts. This is an interesting subject. I always have a shot of adrenalin in my system when I dock my boat. Maybe the only exception is at my home dock.
Tony
Salt Shaker 342
Bow is close to the dock my my inshore drive goes to neutral or stays in fwd and my outside drive goes into revers to swig the stern in, I too am the sole captin and first mate as most my company is pretty clueless and just gets in my way. So I try to have my lines handy and get my stern tied up first then if the boat drifts they toss me the bow line since that's all they are
Capable of, so needless to say I try not to boat under high wind conditions or I'm sol. Cheers and good luck
Most don't know how effective this is in the right situation. I keep a 4 foot bungee cord hanging from the bimini rod nearest the helm where it connects to the side windshield. When I arrive at my home dock, I loop it around the adjacent piling back to the bimini rod. Keeps the boat in place while I am tying up the lines. Obviously the winds and currents are insignificant allowing this technique to work so well with no undue forces on the side windshield. And I dock on the starboard side which helps.
Tony
Salt Shaker 342
:ar!Yes I would say that GLSPRO's marina Is tight. Why they even have a boat on the roof!
Tony
Salt Shaker 342
:ar!
