Replacing a circuit breaker?
davidbrooks
Member Posts: 1,346 ✭✭✭✭
So yesterday my electrical outlets stopped working. If i put a multi meter on them i have 100-120 v between one of the prongs and ground. Nothing between the two prongs. It looks like all of the outlets are on one circuit and the culprit could either be the GFI by the sink or the circuit breaker. I can figure out how to replace the GFI once i drill out the rivets. Why would they rivet the thing in anyway? The big question is how do you replace the circuit breaker? I started to pull out the panel and can get it about 8 inches out of the bulkhead. The back is encased in an aluminum box. In reading posts by @Black_Diamond he had to take out the refrigerator in order to get enough slack to pull out the panel. Is this what you have to do just to replace a breaker or am i missing something?
The way you describe it, you have a fault on the neutral side. You're getting voltage, so the problem isn't on the hot side. It might be a loose connection on the neutral wire rather than a failed breaker. If the problem was with the GFCI, I think you would not see voltage anywhere on the circuit.
By the way -- if you do remove the panel, replace all of the panel lights while you have it out. You probably have some that are burned out already.
- Shut off power
- Remove the refrigerator
- Remove the plastic cover over the Electrical panel with out breaking it
- Remove the 4 corner screws on the panel and start pulling
- Feed wiring up from Refrigerator opening
- Pull on Panel until you can get it all the way out ~ 2 ft
- Remove Aluminum cage on back of panel
- Unscrew Circuit breaker and remove wiring
- Screw in new circuit breaker
- Put everything back together
Ok Rinker lets make this just a little harder.PC BYC, Holland, MI
hope this helps.
