270 trailer winch mount location picture
04FV270riverrat
Member Posts: 268 ✭✭✭
On my 270 the PO moved the winch mount towards the rear of the trailer a good 6-10". I am assuming they didn't trailer it much and this helped to load it at the end of the season on a flatter ramp. I want to move it back forward to help add some tongue weight and make sure it's in the correct spot (or as close as possible). Does anyone have a 270 trailer they can snap a quick photo of the tongue and send me or post on here?
I am also ordering Electric over Hydraulic parts to swap out the surge actuator and want to make sure I leave enough room.
Thanks!
Thanks!
Once that's done you should have the most ideal setup possible.
EoH is a great idea - biggest gotcha is the vehicle-side wiring and controller. Don't assume it works: hook it up and manually test the system. I learned my new-to-me vehicle has the controller and 7-pin plug, but it's lacking the 12V connection required to actually use EoH (I'm doing the same thing). Once I got into the wiring harness I found speaker wire. At that point I decided to remove the existing stuff and re-wire it all the proper way.
*for cargo trailers, it's around 10%. Boats are more aerodynamic and I've always shot for 6% of the total weight on the tongue - that's proven the best ride for me over the years.
