fuel filters on 342 with 5.7's
yeti
Member Posts: 59 ✭✭
When people refer to changing the fuel filter on a Mercruiser 350 MAG MPI are they referring to the fuel water separator, or are there other fuel filters? If there are, where are they? Are there any in the lines that run from the tanks to the engine?
Post edited by yeti on
I have the same setup. There is a water separating filter on the starboard side that looks like an oil filter. Then there will be an inline fuel filter on the fuel hose probably seen in front of the engines somewhere.
Alswagg - Do you have a generic or AC Delco (or other) part number? The auto parts store is full of near matches, but I don't have the dimensions. Access to part this weekened, but not here
There is a company in Lee's Summit, MO that has this in Sierra brand. 18-7721. I change this yearly with the fuel water separator filter.
https://www.firstchoicemarine.com/default.aspx
