Trailer size
Tyce
Member Posts: 3 ✭
I have a 212 Captiva 21 foot Rinker. I need a trailer. I just saw a trailer on offer up near me that held a 20 foot boat. It is dual axle and trailer is 22 feet long. Would this be big enough?
Best Answers
Optionsrandy56 Member Posts: 4,083 ✭✭✭✭✭You probably need a tandem axle, your boat's wt is 3050 lbs dry, without all your stuff, and gas.Boat Name :
Optionsnhsd Member Posts: 182 ✭✭✭There are adjustable trailers and trailers that were designed for a specific boat model. If this trailer is not adjustable it is doubtful that the bunks will be set properly for a 212 as the 212 is wider than many 20 foot boats. Also, if the winch stand is not adjustable it will be problematic given that the 212 is obviously longer than a 20 foot boat. IF the trailer is adjustable, be prepared to have to significantly adjust the bunks and the winch stand for this wider and longer boat.
Dave
Thanks
The trailer does have dual axle so weight is not the issue just length
