Broke top off blue drain plug on water pump
Liberty44140
Member Posts: 4,333 ✭✭✭✭✭
Yep, I did it, couldn’t back out by hand so I used pliers and it broke off. Bummer is that it’s the lower drain hole on the port water pump. I assume I can just drill it out, but what is the easiest way? 3” away from the hole is the stringer so no direct way in. Praying I can do this without removing the entire pump.... suggestions?
You can notch it and use a flat bladed screwdriver to unscrew it.
When you re-install wipe the o-ring with plumbers silicone grease. That is what usually sticks. Can wipe the threads with it too.
Irwin Tools Hanson 53227 Hex Head Multi-Spline Screw Extractor Set, 25 Piece
https://www.amazon.com/dp/B0002SRG66/ref=cm_sw_r_cp_api_i_5bMPDbAX4JAWX
unfortunately no room for dremmel or drill without removing the pump
https://www.hardin-marine.com/p-81079-stainless-steel-lifetime-series-sea-pump-drain-plugs-mercruiser-22-806608a02-8m2000874.aspx
