Anchor pulpit was hit from Starboard side...
Summerrental
Member Posts: 35 ✭✭
Got hit by another boat when they were docking.. they hit my anchor pulpit from the starboard side. See pic... uugh. Does anyone know how difficult it is to replace this thing? I can try to bend it back,... but the other boater is willing to pay for a replacment. Not sure where to get. Also how do I get to the 3 bolts? Are they bolts with lock nuts underneath or just tap screws? Any help is appreciated. Thanks!
Here's the link:
http://rinkerboats.vanillaforums.com/discussion/3828/damage/p1
http://www.amazon.com/Lewmar-LEWMAR-66840008-BOW-ROLLER/dp/B0051J2AWG
@Summerrental, don't want to be a buzzkill but have your fiberglass checked. The same thing happened at out marina a few weeks ago. The tech who removed the anchor roller suggested to the owner that he have a glass guy look at the deck once the roller was removed. he felt the fiberglass had been cracked in several areas. The fiberglass guy, very honest btw and with little extra time to do more work, agreed to look at it and concluded that it had to be reinforced or wave action on the roller while at anchor would definitely cause more damage to the deck fittings. Maybe have that looked at?
They sell all kinds of fancy anchor safety gear. I made a cheap one using that coated wire you can get at Home Depot and a couple of crimps. It's connected to the cleat in the anchor locker and the other end has a lock on it that locks the coated wire to the anchor. About ten bucks all told. Easy to use. I keep the key on a floatie on the shelf under the helm.
(Also ... I have a 270)
