5E Kohler
countrycoach15
Member Posts: 12 ✭✭
I have a 5E Kohler and it is over heating . I have replaced the heat exchanger, T-stat,water pump and cleaned out the strainer . I have used the 1/8 plug on the top to get all the air out of the coolant system and i have good water flow on the sea side . It runs perfect for about 5 min then starts getting angry and back fires and turns off . Heat exchanger is cool but the top by the rad. cap is not . Am I missing anything ?
Are you sure it is overheating? The thermostat is ~190F so the area by the rad cap will be hot to the touch.
Backfiring is usually due to running lean. Do you have the sound cover on yours? Try running it without the cover service door/panel on.
I believe the P/N for the closed coolant side is 359956 (you can search it on google for pictures of where it is). But, I'd find it hard to believe that is the problem. If it truly is overheating, you more than likely have an airlock. I've gone thru the process and it takes a while to get it out. The backfiring has my curiosity though that it could be something else. I'd try what BD mentioned.
I found this in a earlier post (https://rinkerboats.vanillaforums.com/discussion/1883/kohler-5e-generator-please-help) by BD:
2. Replacing the thermostat almost certainly means you have trapped air in the system (a known problem with the 5e)...and it will overheat. There is a bleed plug on top of the heat exchanger, but it still won't get all the air out. I solved this by putting a1/8"NPT barbed hose connector, attached a hand type liquid pump so it pulled from the heat exchanger, leave the pressure ('radiator') cap on, fill the over flow bottle with antifreeze mix and start pumping (you want the suction side conneted to the barbed hose fitting). As you pull a vacuum the air will pull out but be sure to NOT let the overflow bottle go empty as you do this.
I just do not connect the backfiring to overheating. An overtemp will shut the unit off, not run bad.
I’d replace the plugs either way. Mind you there are 2!
there is an inline fuel filter that screws into the fuel pump, follow the fuel line and you’ll have to take the small cover off to get at it. Personally, I got rid of it. Put in a barbed adapter to accept the fuel line. Mind you I have a fuel filter inline by the fuel shut off valve too.
Clean your spark arrestor.
Run with the service door off of you have the sound enclosure. At least on mine, it gets air starved and quits with it on.
Obviously remove top cover, I can usually just push the back cover away. Also a universal joint for the ratchet will help as well with an extension.
There's not much room to lift the cover off due to the cockpit sole. I'm tempted to add an access door through the midberth - that would make things simpler all around.
EDIT: about 5" from sound cover to ceiling of the engine "room".
Then when I tried to restart it took some trying to get going again, but was backfiring. I am going to change the spark plug. .. as suggested here, on most every google search, and from a suggestion from someone at work. I heard the plugs on Koeler gennys are best changed every year.
Praise the Lord
