Sierra vs Mercruiser parts
In the impeller thread, Al mentioned that the Sierra impeller is comparable to the Merc. Does this hold true for most things? As I head towards replacing my own impeller, thermostat, etc.. I wanted to get some feedback on how the quality of Sierra holds up to Merc.
FYI.. On my autos, I OEM wherever I can. I find the aftermarket stuff to be junk.
If Al is using selected sierra parts successfully then I'd have to say that'd be good enough for me. Risers and manifolds, alternators, etc I'd probably stick with OEM. There's a lot of odd aftermarket stuff out there and it seems like a roll of the dice to go out in the OEM market too far beyond Sierra (if it makes any diff).
Good luck with that impeller. I'm SURE it will go better than mine did. #:-S On the other hand I'm like a Nascar tire changer on seawater pumps now.
Mike
Len & Robyn 342 FV Freebird
Great input, Al. I had come across the Mallory name and wasn't sure of its roots. Thanks to you, now I know!
Great to know the point of view of an expert...
I've seen some YouTube videos comparring manifolds and I see your point.. the OEM stuff looks more robust than the others...
