Water going into the generator
Newby here looking for some help. I recently purchased a 98 330 with a generator, 7kw I am told. When underway, water infiltrates it. Water inside a generator is not so good. When talking with Westerbeke about it, they sent me a link to download an installation manual. It appears that the exhaust hose has not been routed outside properly. According to the installation manual, the exhaust hose should go above the exit, then turn down 180 degrees and then turn 90 degrees to exit. Does Rinker have a technical service bulletin on this, or a refit, or can someone help with this?
Best Answer
Black_Diamond
Member Posts: 5,439 ✭✭✭✭✭
Is it WATER or ANTIFREEZE in the oil? If you were getting water in past the exhaust valve you would hydrolock at a minimum.Past owner of a 2003 342FV
Welcome to the forum!
If it is below waterline, you should at least have an anti-siphon valve. Here is a decent site that may help out
http://www.proboat.com/2011/03/generators-done-right/
Now the water intake from the thru hull should have the loop going above the water line and an anti-siphon valve in that (at the top). I can see that causing water to get in the engine if not routed correct or no anti-siphon valve.
For the sake of completeness, the generator exhaust flapper (visible from outside the boat) does not protect against water coming into the boat. That's the job of the anti-siphon valve. The flapper (if present) only reduces how much you spit onto the boat that is tied up next to you.
http://www.myboatsgear.com/vented-loops
