Slow getting on plane
Problem just started. 342 twin 350's, full throttle only gets to 3200rpms and takes double to triple the time to get on plane as before. Once on plane, rpms slowly come up. It's not the load on board. Once on plane I trim as always and its seems the bow is just a tad higher as before. Boat runs the same speed as before set at cruise.
Care sharing info on your bike mount for the front?
Lol
My o-rings had deteriorated on my fuel filler caps, allowing rain water into my tanks. When I began to plane, the water, which was now under the fuel in the tanks, was getting ingested into the fuel lines as the angle of the boat increased with speed. the engines began to sputter with water injection, and wouldnt push through the 2700 rpm barrier.
Check for water in your fuel....if you have separators ...clean them out...replace your filler cap o-rings.
Just an idea, as I encountered a similar issue.
